flash drive
Spud1966
Administrator
Staff member
Administrator
Get it here and not a clone drive ​
About this product​
The Lexar JumpDrive Dual Drive D400 USB 3.2 Gen 1 is a 2-in-1 flash drive that allows you to seamlessly transfer content between your USB Type-C and Type-A devices. Featuring a stylish metal casing and swivel design for added protection, this drive is as tough as it is fast, with transfer speeds up to 130MB/s.
Dual connectors with USB Type-C and USB Type-A ports.
I know it sounds expensive . but crazy prices at the moment
Long as your pc has a USB 3.2 Gen 1 port its fast (and 7zip of winrar your hole DIR structure into one file :)
Tempted, but looks like the USB Type-A only works on Windows but not Android with Type-C as indicated on a site customer review:(
? Enable developer option your android phone , plug and play, if your pc don't have a red port at the back 3.2 and you will only get usb 3.0 speed with that , comes with A and C connection speed on 3.2 ;)
