DOWNLOAD GoCHL: tool for converting CHL lists into lists for the GTCombo with Mars firmware (db).
Blade
Administrator
Administrator
GoCHL: tool for converting CHL lists into lists for the GTCombo with Mars firmware (db).​
A tool for converting our channel lists—originally in CHL format for receivers with Mars firmware—into a format supported by the GTCombo running Mars firmware.
To do this, you will need to:
- export the database file from your GTCombo by going to: Menu > Channel > User Channel List > Save > USB > [Green Button] Save Database
- open the tool and follow the instructions to generate the new database file
- load it back onto your GTCombo
The attached zip file contains the executable and a brief guide.
Thanks Giorgio Team & MATROG
DOWNLOAD
